Index du forum »»  PAC, chauffage, ENR Panne, dépannage, maintenance »» Recherche vue eclaté daikin
Recherche vue eclaté daikin#10956
PsykodelireNoppcarmes
Psykodelire Psykodelireicon_post
Bonsoir tous le monde je recherche la vue éclatée et les références pièce d un groupe extérieur daikin ERYQ007ACV3 DE 2007 merci d avance
Message édité par : Psykodelire / 12-09-2016 19:16
Nop Nopicon_post
http://gsdb.ds-navi.co.jp/gsdb/spb/image/gif/ee32_06/P01_01.gif
A1 1707359 SWING COMPRESSOR
A2 0171173 VIBRATION ISOLATOR
A3 390214J NUT WITH WASHER
A4 1262647 TERMINAL COVER
A5 0401393 RUBBER BUSH, LEAD WIRE
A6 380620 RETAINER, OVER-LOAD RELAY
A7 1707366 RUBBER GROMMET (CUT)
A8 1707373 SOUND INSULATION (SLEEVE)
A9 1707380 SOUND INSULATION (INNER)
A10 1707397 SOUND INSULATION (TOP)
A13 1684766 SOUND INSULATION (MID TOP)
A14 1688218 SOUND INSULATION (REAR)
B1 163116J CROSS-FIN CONDENSER ASS'Y
B1-1 1687905 DISTRIBUTOR
B2 FOUR WAY VALVE ASS'Y
B2-1 1672857 BODY, FOUR WAY VALVE
B2-2 132339J PUTTY
B2-3 DISCHARGE PIPE ASS'Y
B2-3-1 1600179 MUFFLER
B2-3-2 1522952 MUFFLER
B3 MOTORIZED EXP. VALVE / STOP VALVE ASS'Y
B3-1 144130J MOTOR OPERATED VALVE ASS'Y
B3-1-1 138215J BODY, MOTORIZED EXP. VALVE
B3-1-2 111167J STRAINER (FOR REF.)
B3-2 131823J STRAINER (FOR REF.)
B3-3 STOP VALVE ASS'Y (LIQUID LINE)
B3-3-1 1171222 STOP VALVE (LIQUID LINE)
B3-3-2 138233J MUFFLER
B3-4 137963J PUTTY
B4 131334J STOP VALVE ASS'Y (GAS LINE)
B4-1 1632789 STOP VALVE (GAS LINE)
B5 131312J ACCUMULATOR ASS'Y
B6 115271J PUTTY
B7 007993J CAP, STOP VALVE
B8 250004J FLARE NUT
B9 1052073 BLIND CAP, FLARE NUT
B10 045432J CAP, STOP VALVE
B11 119847J FLARE NUT
B12 1020920 BLIND CAP, FLARE NUT
B13 380116J CUSHION RUBBER, ACCUMULATOR
B15 112853J SOUND ABSORBING PUTTY
B16 139731J PUTTY
B19 SUCTION PIPE
B20 380120 FITTING SPRING, THERMISTOR
B21 1107384 FIXTURE, THERMISTOR
B22 1684805 SEALING MATERIAL (HEAT EXCH.)
C1 1684812 FAN BLADE ASS'Y
C2 847002J LOCK NUT, FAN BLADE
C3 118238J GUARD NET
C4 163114J AIR DISCHARGE GRILLE
E1 1684829 BODY, SWITCH BOX
E3 1707669 HEAT SINK ASS'Y
E4 1684843 SWITCH BOX ASS'Y
E4-1 1684850 SEALING MATERIAL
E5 1707676 WIRE HARNESS ASS'Y (for other than COMP.)
E6 1770915 PRINTED CIRCUIT ASS'Y (CONTROL)
E6-1 1684881 FUSE
E6-2 153875J FUSE
E8 TERMINAL BLOCK ASS'Y
E8-1 1684913 TERMINAL BLOCK
E8-2 1684920 TERMINAL BLOCK
E8-3 1688256 PRINTED CIRCUIT ASS'Y (SERVICE MONITOR)
E8-4 136116J SET SCREW
E8-5 1707690 COVER, TERMINAL BLOCK
E8-6 1707708 INDICATION LABEL (TERMINAL)
E12 1684951 THERMISTOR ASS'Y
E13 622418J OVER-LOAD RELAY
E14 1707715 REACTOR
E16 130278J COIL ASS'Y, MOTORIZED EXP. VALVE
E16-1 130961J COIL, MOTORIZED EXP. VALVE
E17 1684968 COIL ASS'Y, FOUR WAY VALVE
E17-1 148574J COIL, FOUR WAY VALVE
E18 0590806 FIXING BAND, LEAD WIRE (A)
E19 059320J INSULATOR (A)
E20 1688263 DC FAN MOTOR ASS'Y
E22 113783J GROUNDING TIP (W/WASHER)
E23 130707J CUSHION RUBBER, SWITCH BOX
E24 1707722 PLASTIC BAND
E25 1684982 WIRE HARNESS (FOR COMP.)
F1 1656963 BOTTOM FRAME ASS'Y (PAINTING)
F2 1688270 SIDE PLATE ASS'Y (RIGHT)
F2-1 1688287 VIBRATION ISOLATING PAD 2
F2-2 1687943 SEALING MATERIAL (RIGHT)
F3 139741J SIDE PLATE ASS'Y (LEFT)
F4 1688294 FRONT PLATE ASS'Y
F5 1685031 PARTITION PLATE
F6 163127J MOTOR BASE
F7 1688302 COVER, STOP VALVE
F7-1 1437410 SEALING MATERIAL
F7-2 1687950 SEALING MATERIAL
F7-3 1687967 SEALING MATERIAL
F8 1688319 SHIELD PLATE
F9 1379754 HANDLE
F10 163129J MOUNTING PLATE, STOP VALVE
F12 140380J TAPPING SCREW
F14 109224J HEX. HEAD TAPPING SCREW
F15 008203J TRUSS HEAD TAPPING SCREW
F16 048017J PAN HEAD TAPPING SCREW
F17 118234J TOP PLATE
F18 1685062 SEALED BOARD ASS'Y
F18-1 1437410 SEALING MATERIAL
F21 144136J HOLE PROTECTION RUBBER
K1 1721874 MODEL NAME LABEL
K2 0589565 DRAIN JOINT
K4 1370409 NAMEPLATE, INDICATOR PANEL
nop
Nop Nopicon_post
ok merci a toi est bonne soirée
pcarmes pcarmesicon_post
Salut tu peut utiliser les identifiants suivant, il me les ont passé pour trouver une pièce détachée.
Identifiant : FR_ALL
Mot de passe : 111111
Bonne soirée.
