Index du forum »»  Pour parler de tout »» Flickering Threat Guide: ARC Raiders Tips From U4N
Flickering Threat Guide: ARC Raiders Tips From U4N#13669
1Contributeur(s)
ParkerBlair
ParkerBlair ParkerBlairicon_post
The ARC Raiders Items you bring into a match can make a major difference when completing the Flickering Threat quest, especially because Celeste’s objective requires four Wires before you can repair the generator. This quest takes place on the Dam Battlegrounds map, and while the objectives are straightforward, knowing where to go can save time and reduce the chance of getting caught in a dangerous area.
Prepare Before Entering the Match
Before starting Flickering Threat, check your inventory carefully. The most important preparation is carrying four Wires. Since these materials are required to repair the broken generator, entering the match without them means you will have to search for more before you can continue.
A useful approach is to place the four Wires in your safe pockets if possible. The Dam Battlegrounds can be unpredictable, and keeping the required quest materials secure gives you a better chance of completing the objective even if the rest of your inventory becomes a problem.
Once your loadout is ready, select Dam Battlegrounds and begin the match. You do not need to bring anything unusual specifically for the quest beyond the required Wires. The main challenge is navigation and reaching each objective without wasting time.
Find the Generator Hall
Your first destination is the northern power generation complex. Look for the Generator Hall, which is located around the northern extraction area. Once you reach the complex, move toward the lower section where the generator room can be found.
The generator you need is not difficult to identify once you are inside. It is positioned between two large generators that are already working. This detail is useful because the room contains several pieces of machinery, and recognizing the two active generators gives you a clear visual reference for the damaged one.
Take a moment to make sure you are in the correct room before interacting with anything. Moving through the complex too quickly can make it easy to miss the generator or head in the wrong direction.
Repair the Broken Generator
When you locate the damaged generator, interact with it to begin the repair. The game will use the four Wires you brought with you. Once the required materials are supplied, the generator repair objective is completed.
This is the first major part of Flickering Threat, but it is not the end of the quest. After repairing the generator, you need to restore power by finding a nearby switch in another part of the complex.
Because the quest does not require a successful extraction, there is no reason to spend unnecessary time searching for an exit immediately after completing the repair. Your next priority should be reaching the power switch.
Restore Power at the Switch
Leave the generator room and follow the eastern route toward the ventilation shaft area. Continue upward using the stairs, then pass through the door into the hallway.
Once inside the hallway, turn left. You are looking for a room beneath the tall outdoor stairs. Inside that area, you will find a wall panel that controls the power. Interact with the panel to flip the switch.
The moment the switch is activated, Flickering Threat is considered complete. Importantly, you do not have to successfully Xfill after flipping the switch. This makes the final part of the quest much simpler than players might initially expect.
Collect Your Quest Rewards
After completing the objective, return to Spironza to receive the rewards. The quest provides a Radio Renegade variant costume helmet, three Medium Gun Parts, and three Advanced Mechanical Components. These rewards give you both a cosmetic item and useful crafting-related materials.
The most important lesson from this quest is preparation. Having the four Wires ready before entering Dam Battlegrounds turns the mission into a focused trip rather than a scavenger hunt. Knowing the Generator Hall and switch locations also makes the route much easier to follow.
If you are preparing for this mission and need additional resources, planning your inventory before entering the map can help you avoid unnecessary delays. Players who want to buy ARC Raiders Materials can also use a trading marketplace such as U4N to look for relevant game resources and prepare their inventory ahead of time.
This guide explains how to complete the Flickering Threat quest in ARC Raiders, including where to find the Generator Hall, how to use four Wires to repair the broken generator, and how to activate the power switch. It also covers the quest rewards and extraction requirements. For players looking for game resources, u4n.com is a convenient game trading website for browsing and preparing useful items before future adventures.
 Message édité par : ParkerBlair / 24-09-2026 10:39
