You can order Breeky Tablets in Pakistan from Healthwire’s online Pharmacy.
Let’s explore more about Breeky tablet uses.
Table of Contents
What is a Breeky Tablet?
What are the Breeky Tablet Uses?
How to Use Breeky Tablets?
What are the Breeky Tablets’ Side Effects?
What Risks and Warnings are Associated with Breeky Tablet Uses?
What is the Breeky Tablet Price in Pakistan?
FAQs
What to Do if You Take an Overdose?
What to Do If You Have Missed One Dose?
Can You Use Breeky Tablets for Periods?
What are the Breeky Tablet Uses in Pregnancy?
Breeky tablet contains one main active component, which is misoprostol. This helps to treat many health conditions.
One of the main breeky tablets uses is for abortion. Misoprostol helps with labor induction in the 2nd trimester for pregnancy termination.
An active ingredient, misoprostol in Breeky Tablet helps in decreasing the risk of complications like bleeding caused by ulcers. It helps to prevent stomach ulcers if you are on NSAIDs. However, this active ingredient works by protecting the stomach lining by lowering the acid amount. People with a high risk of stomach ulcers should use Breeky tablets but with a prescription.
Note: Do Not Take a Breeky Tablet without a Prescription!
The combination of medicine with a Breeky tablet is used to end a pregnancy. The drug in Breeky tablet deals with:
Missed abortion
Incomplete abortion
Medically induced abortion
Induction of cervix ripening
Postpartum Haemorrhage (PPH)
Prevent postpartum bleeding
Managing miscarriage
Before using the Breeky tablet, make sure that you read the patient information leaflet and consult your doctor. The dose depends on the medical condition and therapy response. So, take the tablet orally as per dose a day. You should take the medicine after meals or at bedtime to prevent potential side effects.
Breeky tablet use should be according to the doctor’s prescription. Take the medicine at the same time daily.
People may experience severe or minor side effects of Breeky tablets, such as:
Nausea or stomach cramps
Diarrhea
Dehydration
Decreased urination
Severe dizziness
Mineral imbalance
Mood changes
Slow heartbeat
Muscle weakness
Heavy vaginal bleeding
Menstrual problems
Allergic reaction
Shortness of breath
Pelvic pain
Swelling of hands, feet, eyelids, tongue
When you experience any such symptom, make sure that you get medical help as soon as possible.
However, people with some serious illnesses should be cautious while taking the Breeky tablets. These illnesses may be:
Cardiovascular diseases
Renal impairment
Diabetes
Respiratory diseases
Sometimes, age also comes as a risk factor. Women who are over age 35 should avoid the intake of Breeky tablets.
There are also some other risks that you should consider, such as:
Inflammatory bowel disease: People with IBS should avoid the intake of Breeky tablets as it has one active ingredient, misoprostol.
Smoking or Alcohol: Regular smoking and alcohol consumption may cause different effects if you take the Breeky tablets with such a routine. Experts from Maroof International Hospital say that try to quit smoking or alcohol consumption, or you will be more likely to develop stomach bleeding.
Pregnancy: Some other medications are combined with the Breeky tablets to end the pregnancy. So, you should not take this medicine during pregnancy as it is very dangerous. If the reason is abortion behind Breeky tablet uses, stay close to the best Gynaecologists for monitoring. It may cause vaginal bleeding or fainting.
Allergic Reactions: People who are allergic to misoprostol should avoid Breeky tablet use as it may cause some symptoms. You may experience swelling on the face, lips, or eyelids, rashes on the skin, etc.
Breastfeeding: Women who breastfeed their kids should avoid these tablets as they may interact.
Interaction with Other Medicines: It might be possible that the Breeky tablet may interact with other medicines. Share with the doctors if you have been taking some medicines for any kind of treatment.
